If you own a Festool Kapex
Dick Coers
Long story short, don't cut off short pieces of 3" dowel stock without a zero clearance fence.
Long story; Cut off a 3" long piece of 3" maple dowel I had turned. I think the round cutoff rotated at the end of the cut and it sounded like the saw exploded. The cutoff had climbed up and ejected through the opening of the fence. Can't say for sure if I let the saw head pivot up or not. Anyway, the blade had a horrible wobble. Ordered a new blade. Put new blade on, still wobbled. Watched a youtube video on rebuilding the saw, and decided pulling the shaft was only three bolts, so why send it away. Easily pulled the shaft assembly out, put it in a vise and brought up a dial indicator. Zero runout, so didn't bend the shaft. By chance I looked at the back saw blade washer. It was bent so badly I could see it with my bad eyes. Put the two washers together, the gap was more than 1/32" off from one side to the other. Could not imagine how the blade deflecting could bend that washer, but ordered a new one. $32.41 and I'm back in business! Well that and the new blade I didn't need. I definitely checked all my digits when that cutoff exploded through the saw. Luckily had my hands in the correct places. Very fortunate!
