A55 Smoothing Plane
Final result of help from folks here
mfoster vermontel.net
I had a question a few months back on how to resaw a blank accurately that was 4" thick so that I could glue up a grid. I was thinking about using the tablesaw but was talked into using my bandsaw with a new blade and it worked like a charm. I think Bill Tindall and others helped me out with that. Then I had an issue as the blank I made and turned was all exposed endgrain walnut and I did not know how to deal with the open pores. Michael Dresdner and others helped me with that. I wanted to thank everyone that helped me out, and now I can finally share the result of that work. I entered this piece into the AAW juried show titled Continuum, and can now boast that it made the cut and will be in the show. Thanks for all your help.
Re: Final result of help from folks here
Clint Searl
Great looking
Time/Space
Gary Smyth
WOW. Bending time. Your project is almost as complex as the mental theory. Congrats! Theoretical scientists ought to be fighting for this one. Be sure to copyright image -- sure to be published.
Re: Time/Space
I was thinking along the same Lines. The Gravity of the piece has a hold on me.
Very nice! Three associations, lines,gravity,hold
walta
A friend of mine had made platters with a similar pattern. While interesting I did not care for the effect but with the sphere it is perfect.
Walta
Re: Time/Space
Gary, you nailed it. This is titled Space-Time. I am a physics nerd, though I don't really understand the math. I do read the latest books by the greatest thinkers in physics that are geared toward the lay person. This is a classic image use to express Einstien's theory of relativity interaction with massive objects. I just tried to make it a 3D expression. I think I did well, as so many have instantly recognized the theory behind the art like you. Thanks.
Don Orr
That's awesome Mike! I'll bet Einstein would be impressed. Congrats on the show.
Very cool!
You've done it again, Michael. What an astounding piece, conceptually and in its execution. I'm glad you were able to find the help you needed here.
Thanks for posting and good luck in the contest.
Arresting
There are rare occasions where something just stops me in my tracks. I couldn't stop from focusing on the work. Anyone that has been exposed to this theory will spot this piece among the many and instantly be drawn to it. I've run out of words to describe its impact..........
I don't know what your intention is for this piece but don't underestimate it value.
Can't stop looking
Gary Smyth
Much, much different than yours.
Question
Considering the end grain, were the blocks and/or the surface finish degassed? Over time, trapped air in the wood pores and maybe the top coat may try to migrate upwards resulting in swelling bubbles. Such a happening can be significant.
Question...
Mike Farinella
Does the earth orb rotate within the piece? It reminded me of such orbs I've seen at jewelry stores that did exactly that.
Re: Can't stop looking
Michael Foster
Not de-gassed. I wouldn't know how to do that and had no idea it should be considered. Just used a lacquer finish. I posted on here that I was having trouble filling the pores given it was all end grain while putting on multiple coats. Michael Dresdner clued me in on a product I hadn't heard of, pore fillers. I gave this a try even with lacquer already on it, and it worked like a charm. Wish I had known about it before applying any finish, but at least now I know. I hope the finish stay nice in the future.
Re: Question...
Michael Foster
No, it doesn't rotate. It is just sitting on a spindle and can be removed easily as it is just a mortise and tenon with no glue. I did this intentionally to accommodate shipping.
Rotating globe, just for fun
I'm certainly not suggesting you go with this for the globe, but they might be interesting if you haven't seen them. https://www.movaglobes.com/
These have solar cells and use rotating magnetic fields to rotate a globe inside a clear plastic sphere. We have had one for years now and it's amazing. It rotates VERY slowly and even in dim light, somewhat faster in bright light. (It doesn't need the stand, will rotate the same even held in the hand. The globe is floating in a liquid and weighted so the axis is always vertical so it wouldn't be true to the earth's tilt relative to the ecliptic. I think the smallest one is 4.5" in diameter. Not what I would call cheap...
question
Now that you have dazzled us with this creation provide some details of how it was assembled. Alignment, and keeping alignment, of the "lines" during assembly must be difficult. There must be some techniques to get it right.
glueup
I'd love to see progress photos if available.
I've watched Frank Penta make related things with a series of slice an dice with veneer between, but thinner. Alignment seems tricky, perfect on this piece from what I can see.
Re: Rotating globe, just for fun
Howard Pollack
John- does it rotate smoothly?
Howard
Howard Pollack
This is a stunning piece!
Yup.....
"erfect on this piece from what I can see"
There must be some "ticks" to achieve perfect.
Re: question
Hi Bill, I tried to reply this morning before going to work, but I got an almost screen of death when I hit post. I have had trouble with the site loading correctly for a couple of days. I will get a screen that lists some of the sponsors with links, but no message board. Not sure if that is something others have experienced.
So I originally posted the pic shown here. This blank is made from 4" lengths of 12" wide Peruvian walnut (a richer, darker walnut and this board, at least, had no sapwood. Veneer is Birch that also runs vertically. Here I was contemplating trying to re-saw the blank on the tablesaw as I wanted nice clean cuts with very controllable thickness to get the grid right. Your advice, and others, was to use the bandsaw. I put a new re-saw blade on the bandsaw and got the fence adjusted to a tee, then sliced the blank up. The cuts were so good that no sanding was required and all I had to do was glue up the slices with more veneer between each slice. I did glue up just one veneer at a time between 2 slices as then I had time to get the cross veneers lined up perfectly. Trying to do more in a glue up would have been un-manageable. Once the glue up was done, then came the real trick, turning it. I mounted it on a faceplate and turned the wings first. The issue here is that the wood is oriented up and down, and taking too big of a cut could easily chunk out wood as the piece got thinner. Think high speed and super sharp gouges and a very light touch taking just slivers each pass. I was nervous during the whole process till I got those corners the thickness I was after and totally stoked that I was able to pull it off. Turning a square blank is intimidating enough for lots of folks, but with the grain running vertically as in this piece just adds a whole nother layer of comlpexity. So again, thanks for the help in getting me to the finish line on this.
Yep, I have seen these and they are fascinating for sure. My challenge in this type of work is for everything I show having been made by me so putting one of these in place of my globe just wouldn't make the mark (unless I somehow figured out how to make these, which is not likely)
your secret is revelaed
You have the patience necessary to do what was required, and that was your trick.
I had someone highly experienced help me a hollow in an end grained cutting board that was comfortably round. I became impressed that turning end grain is not similar to flat grain.
Again, nice job.
