Bandsaw Blade Jumped
Don Stephan
My bandsaw is an older Minimax I've had for about 12 years, using it occasionally. This afternoon I was sawing into lidded box blanks a 4" thick slice through a green walnut log. After 7 or 8 minutes without issue, the blade suddenly jumped off one of the wheels 1" into the next cut. As best I can tell the bearings are still set properly, both the side bearings and the thrust bearings behind the blade. The tension was set as usual. The wheel tires don't show any nicks or gouges. This afternoon I didn't have time to put the blade back on the wheels but did straighten out the bends that happened with the blade jumped, and I will try to continue tomorrow after confirming the setting of all six bearings. This happened once, when the set screw on a thrust bearing shaft loosened and the thrust bearing slid back, allowing the blade to work off the back of the wheels.
besides the bearing placements, what else should I check before trying to continue tomorrow? (I'd put on a new blade, but don't have an extra 1/2" x 3 for green wood.)
