18th Century Wood
18th Century Wood
18th Century Wood
The first settlers had virgin forest to choose furniture lumber from. However, these settlers were not able to take advantage of this timber to build fine furniture for their log homes. Later in time when cabinet makers were furnishing more substantial homes some astonishingly low grade lumber shows up in the early 1700's Chester County furniture.
The drawers for this piece were made from at best what we would call today #2 Common lumber . It may not be obvious from the low res picture but every drawer has a knot we would never include in a drawer. Some are 1.5" across. The top of the piece under discussion below was made from similarly knotty lumber.
Walnut is not a common tree and it would have been even less common in the virgin forests. Perhaps high quality logs were getting scarce at this time. Transporting a 1000 pound log much distance to a mill would have been a time consuming task. Or, the price of higher grade lumber was out of reach for country furniture, if lumber was sold by the board and not by the tree.
I have records of shop inventory of some Chester County shops. Wood is inventoried by species but no comment is ever made about quality of the walnut, cherry and other wood. It appears that shops maintained an inventory of lumber and did not rely on a lumber supplier to fill needs on a job by job basis. It is easy to speculate that shops just bought what a log yielded and used the result as best they could.
Re: 18th Century Wood
Dale Stansbery
Or, they may have considered what you're calling defects just character. Depending on what part of the country you're from, walnut was quite plentiful. The old original barn on our farm had up to 40 foot 12"'x12" walnut beams. Our 150 year old house has it's original walnut siding. I'm in N.C. Ohio
AZ in Colorado Springs
Were they less fussy when boards were cut using pit saws and human muscle power? Not that 18th century woodworkers would have been able to envision a wood mizer or a V-8 powered sawmill, but their assumptions may have been different from ours. You alluded to that by acknowledging transport difficulties.
In Colonial times....
all the trees belonged to the crown. If you cut one down, you were cutting the Crown's tree. But if one blew down, you got a Windfall and it was yours. That's the definition of Windfall. Maybe that's why prime timber was not as plentiful as might be imagined.
Brian Holcombe
Perhaps it was built according to the budget of the client.
Warren in Lancaster, PA
Figured wood was desirable; the customer probably paid extra for these drawer fronts. Note that the cove mouldings are made from clear stock, as are the feet. And probably the frame members on the sides.
It takes extra labor and extra skill to make drawer fronts like this.
Brian Holcombe
Thanks Warren, I appreciate your insight.
Joe in a Cleveland suburb
Brian,
I saw your piece in the April 2019 issue of FWW. Very nice and congratulations.
Brian Holcombe
Thanks, Joe!
