Need a fixer-upper air compressor? *LINK*
Re: Need a fixer-upper air compressor? *LINK*
Kneale Brownson
Re: That's Rust, looks like.
Kneale Brownson
I replaced a tank on an otherwise functional portable air compressor before I learned to drain a compressor tank after each use if intermittently used (I have continuous drains on compressors in regular use). Tank developed a leak I stopped with a screw and rubber washer and then, within a month, became swiss cheese-like on the bottom.
Jim DeLaney, Austintown, Ohio
A friend had one explode like that. Shrapnel put him in the hospital for several days, and wiped out the whole side of his Corvette.
Dangerous stuff!
Howard in Toronto
Wow. That'd be enough to scare fertilizer out me...
