How to attach "pickets" question
I am building a bed for my Son and DIL. Sort of Arts and Crafts style. Has a row of vertical slats about an inch wide and spaced about an inch. About 36 of them.
How to attach them?
I could cut a slot and then put a spacer between them.
I could punch square mortices and insert them.
I could use Dominoes.
Or???? What?
How would you do it?
Re: How to attach "pickets" question
Jack Guzman from Maine
I did something similar in a crib side. I made a groove in both rails and put spacers between the slats.
David Yoho
I'm assuming these will go between two horizontal rails either on a headboard or footboard. Make life easy on yourself and go with the dominoes.
John McGaw
With the equipment I presently have I'd select slot and spacers as the easy way and mortises as the hard way (I don't have a vertical mortiser and would use my horizontal but it makes rounded ends which would need chiseling). I don't have a Domino machine and I don't know how thin your slats are but I'd be a bit concerned about cutting endgrain into thin wood on general principles.
