Veritas - Innovation in Tools
work table finish
work table finish
Jack Guzman from Maine
work table finish
I built a low assembly table for my chair shop. I use it for assembly and finishing chairs. I will be spilling glue,milk paint and various oil/varnish finishes on it. Also water occasionally. I want to be able to wipe it down to clean it after use without stuff soaking into or sticking to it. I coated it with some left over milk paint and want to coat this with something fairly durable. What can I use for this purpose? Is water based urethane designed for floors appropriate?
Re: work table finish
I cover my similar bench with 1/8" Masonite and throw it away every few years.
Oil based porch paint is the most durable coating I know of but it takes days to fully cure. Oil urethane varnish will be good also.
Dick Coers
I’d suggest 1/4” melamine, or thinner waterproof panels from the box stores. I think Menards calls theirs, plas-Tex. Around $30 and really tough.
the problem with Melamine
If what you put on the bench does not transmit moisture your bench will cup as one side changes moisture and the other doesn't. It was for this reason I suggested 1/8" Masonite or some sort of inexpensive underlayment plywood. I have used Masonite for years after having bench cup from melamine. I will go to lighter color plywood underlayment next to get a lighter color.
porch paint
I like the idea of porch paint. I'll do it in the spring when I can paint it outdoors.
Re: the problem with Melamine
Don Stephan
Another issue with 1/4" melamine, at least what I was able to buy here in Cincinnati years ago, was that the coating was not the same durable surface that was on 1/2" and 3/4" sheets, but something the distributor called "foil" which was not as durable.
Clint Searl
Clint Searl
Varathane waterborne floor finish. It's bulletproof.
Thanks. That's what I'll do over the milk paint.
I used Varithane Urethane on some steps. The Version that is not water borne, whatever that is. Mineral spirits for cleanup. It has Aluminum Oxide in it to enhance wear. Fabulous floor finish. The grit in it might be good on a workbench to keep the surface from being slick. Unless slick is a good thing.
Pete in Holland MI
Formica or a similar laminate. I have source for used commercial office work surfaces and love them. I make my work tables from them. They're tough. Most spilled paint/varnish/glue comes off with a scraper. Else, a little solvent doesn't touch the stuff. Check various sources for just the sheet stock and properly glue it to your surface. Deals can be had with out of date colors. It doesn't look "old world", but is very durable. It also doesn't transfer to a project, as paint or oil would.
Pete
White tile board
Home Depot has white tile board in either acrylic or PVC.
I've used them on a couple of my benches.
When I made my wall benches, the glue up surface and the sharpening bench has the white tile board.
The other benches have 1/4" masonite finished w/ polyurethane.
