Petrified Wood table stretcher joinery
note: something about the orientation of the picture makes the legs appear larger at top than bottom. This is not the case for these legs; they are significantly smaller at the top.
While the stretchers could have been difficult to execute and fit some inspired engineering up front made these operations trivial. I previously described how the M&T joints were made so that stretchers could be simply cut on the table saw at 90 degrees, with no odd angle fitting required. The lap joints are similarly simple, because I preserved a flat reference surface until the cuts for the joints were completed..
First cut rectangular stock to finished length as determined from full scale drawing. Then lay out the pattern in the case of the bottom stretcher.
By flipping the stock end for end and registration against the fence the half lap slot is ensured to be centered. It is just a matter of care to get the width right.
And if the slot is cut before the arc it is ensured to be perpendicular to the base of the table.
Re: Petrified Wood table stretcher joinery
Joe in a Cleveland suburb
What did you decide about the bull nose profile?
Inquiring minds want to know. :)
See here...
Re: Petrified Wood table stretcher joinery, Aside
I am enjoying the discourse on the table base and it appears it is going to turn out very nice. That's a spectacular piece of "wood".
My suggestion is to put some sort of frame under the top to prevent the table from twisting in a circle. Probably not necessary, but it would be a shame if it did. Wouldn't take much.
Don't doubt my engineering ;) As you might imagine I sized the "frame" so the legs appear to have grown around and among the rock. It is plenty ridged just dry fit.
I figured....
It was pretty strong, but I would hate to hear that someone leaned on it and it went into a death spiral for both of them. A bad way for one of your drunken friends to get stoned. :b
Kneale Brownson
That's going to be a spectacular piece, Bill
Well, not....
In the next installment I will describe where I ran out of skill and motivation. It will be just a good functional piece.
