Veneered Dining Room Table?
Tom Norton
Looking for thoughts on building a veneered top. Maybe some type of highly figured maple. I have the vac bag that will handle the size.
So what say ye????
Re: Veneered Dining Room Table?
Dick Coers
Why not?
Absolutely!
Tony - Memphis
Maybe throw in some inlay and crossbanding as well?!? I've done several small tables and such. Love the stuff. You can get figure that makes you drool! We have a 'furniture store' dining table that is crotch mahogany that is unreal. How big are you planning?
Alan Young
Re: Veneered Dining Room Table? *LINK*
Alan Young
I made this Dutch Pullout style table using relatively thick (.06")walnut veneer.
Closed- 42" Wide and 72" Long. Open- 42" Wide and 108" Long.
I have a vacuum press but it wasn't big enough for this project so I had a very long veneering process- You can follow my approach on the link...
Dining Table fabrication
Don Stephan
Certainly Wood has some veneers thicker than "standard" today. For a larger project, I would recommend a thicker veneer which will tolerate more level sanding after pressing without a sand-through.
Keith Newton
That may depend on your skill level. Having a tool does not acraftsman make.
The way you stated it, I suspect you may not have ever bagged a project this large before. Choosing the wrong glue could get you into trouble by running out of open time before you get the parts into the bag before achieving a good vacuum.
You would do well to give as much detail as you can, so anyone willing to give advice can stear you away from pitfalls.
So true!
Tony - Memphis
I have a shop full of really nice tools, but I don't consider myself a very good woodworker. How many times have you heard folks say..."If I had the those tools?" Mostly in reference to Norm. Ha!
Tony - I've seen people do a whole lot more with a whole lot less...but I keep trying.
TomD
One of my first projects was a 4' x 24' deal. I used slow set epoxy and had to run it for about 8 hours. Turned out perfect. I used the shop vac for the vac, but that only worked because I wasn't using the perimeter for the most part, and the panels were flat. Veneer needs more pressure. I veneered the inside of the cabin with purple heart which turned out great, but looked too dark.
You only get to be the experience guy if you jump in with both feet. Well at least if you are limited to your own shop.
