I Just added the counter weight to my DP
I had some 5 lb ingots of lead and I bought some 1/16" cable and a pulley. Hung the pulley for the bottom of the upper housing, wrapped the cable around the bolt that holds the table and attached 20 lbs of lead. Drilled through the center of the lead.
I cleaned and waxed the column with paste wax. With one whole minute of use under my belt I can say I am pleased. Pretty much got neutral buoyancy. Very pleasant to adjust.
I recommend this upgrade if you don't have something similar.
C & C welcome.
