Hollow chisel mortises vs Domino
I recently made three tables where the legs were mortised into rails, conventional table construction. The mortises are shown in Picture 1. I bought a used Domino to evaluate it for this kind of task. The leg used two biscuits per rail, 4 mortises per leg. The rail was inset 1/8" from edge of leg face. A total of 32 mortises per table had to be cut. Four set-ups (fixing the fence on the machine in two dimensions, had to be made. This set-up was not quick. And each leg had to be secured before cutting. It was quick to cut the each mortise once the machine fences were set up. The location of the mortises was precise and there were no fitting problems of rails to legs.
The biscuits fit nicely into the end grain mortise of the rails. They did not into the flat grain of the legs. Most biscuits had to be diddled with to get an acceptable fit, that is, could be slid into place with hand pressure.
Had I cut the mortises with a chisel mortiser I could have cut one long mortise. Once the fence was set up on the mortise machine all the leg mortises could be cut with no further adjustment. The left and right handedness of the leg mortise could be dealt with by reversing the leg in the machine vice.
Making this table with the hollow chisel mortiser would have been much quicker, at least in my hands. Recall, I thought the Domino was faster for making case back frame and panels.
