A coffee table for my nephew - #7
Finishing the base ..
Splayed legs leave their tops angled with the rails, and they need to be flushed ...
... to be coplanar on both sides ...
The next step was to add corner reinforcing blocks. These were glued and screwed ...
You can see they follow the angled rails (created by the splayed legs).
The under side ..
The final stage was to level the legs. Measure the height at each corner, and use wedges under each leg until the height is the same for all ...
Hot glue the wedges so they do not move ...
Once done, scribe the bottom of each leg ...
Electrician's tape is great for marking at an angle ...
Saw off the waste, and we are done ...
I checked the result with a digital angle box. All good. Sanded to 240 grit ...
The drawer and finishing is left to do.
Re: A coffee table for my nephew - #7
William Duffield
Did you measure the angle of the reinforcing blocks or calculate it?
I was also wondering about a design decision on the top: It seems that no one would have ever noticed if the fillets inside the dovetailed corners, and in particular the top fillets, weren't continuous the whole width of the table. If you had extended them only a couple of inches from both sides, would it have significantly weakened the dovetail joints?
I need to remember your clever means of leg leveling.
My first thoughts were that the leg assembly looks frail. I think it is frail. However the box that sits on it is ridged under any imaginable load. Any vertical load, like one of my recently visiting grand daughters doing hand stands on it (but that is another story), will be carried by the legs only.
weakened the dovetail joints? !
Every fiber of this assembly would splinter before these many well-made dovetails would fail, fillet or not.
However, since there is no intention of putting a drawer in this space, I too did wonder about the need for a full length fillet.
Hi William
I did consider having just the ends of the corners with end grain sections and long grain in the middle. But that was when I planned to plane the hollows with planes. I did not think of just doing the outer ends alone - it would be noticeable to anyone looking through the table, such as when inserting a magazine.
The filets do not reinforce the dovetails. They simply extend the round corners.
Bill, I am hoping that the corner brackets boost the strength of the legs significantly. In my mind, what they do is create a sort-of dovetail by triangulating the mortice and tenon. The leg cannot more forward as a result.
These legs are typical of the style of Danish Modern. One wonders how they fared over the years. Not my first choice of design. The worst case scenario is I shall be re-making a base in the future (don't think it!).
Don Stephan
Did I see seven round marking gauges in the background? (lol)
Don, yep! :)
Two are Titemarks, two are Veritas (when they had a special a few years ago. The SS versions were an absolute bargain), one is the new adjustable Veritas (sent to me for preproduction assessment), then there is the double arm Veritas mortice gauge, and one I made (with a wide head for extra registration - the plan is to use this one also for a panel gauge).
Generally, I can have 2 or 3 cutting gauges in use at all times. They are used to transfer marks, rather than using a scale/ruler.
