A coffee table for my nephew - #4
I assembled the carcase today. This began with glueing the one end and, while that dried, fitting the sides of the drawer box ...
Someone predicted that this glue up would be interesting. Was it ever.
I had this plan to glue the ends, attach the drawer box, and then simply drop the top side into place. What could be easier?
Except ... I realised as I positioned the drawer box dividers in their stopped dados - and was just about to glue in the other end - that the ends were tails and the top section had pins ... and they needed to be slid in horizontally, not vertically! The order of assembly should have been: fit drawer box to open base, add top section, now add one end and then the other.
I removed the drawer box parts, and attached the top panel to the already glued end. Lifting the top at an angle, the drawer box dividers were wiggled in. And then I discovered that they were 10mm too high!
Oh hell (or some other descriptive) .. I propped up the top panel, quickly calculated how much needed to be removed on the table saw, did both dividers, rebated the ends again ...
... it fits ... (phew)
.. up ended the monster (which weighed a bloody ton, but I was now a demon possessed of desperation strength!), glued in the last side, and squared the carcase ....
And everything is square ...
I'll clean it up tomorrow, and then start on rounding the ends.
Re: A coffee table for my nephew - #4
Hank Knight
That looks gird, Derek. As usual, I'm enjoying watching this build. Thanks.
Thanks Hank ... I am busy watching your build as well. The sliding dovetails look so neatly done!
Best wishes for the new year!
Hank Knight
Thanks, Derek. Happy New Year back to you. You guys are already in 2019, aren't you?
No matter how experienced I think I am, episodes as you describe have led me to ALWAYS dry fit a case. I was tense and sweating just reading your description.
Bill, I had done a dry fit of the individual parts. Just not everything together, as assembling the dovetails, and then dissasembling them runs to risk of chipping and cracking. The wood is hard and has fine gun veins. As a result it is vulnerable. During a test fit, one side did crack in half as I tapped it off. Fortunately, the glue repair is invisible.
So I visualise a lot. This time I was clearly delusional. If thta gives you the sweats, what actually happened - I must have suppressed the memory when writing - was that I did glue on the second end before discovering that I had effectively gone down a dead end! Thank goodness for Titebond hide glue - long open time and I could clean up in warm water. Then it can be re-glued. I am in a position to confirm this! :)
Happy new year.
Bruce, a MN Galoot
Glad you mentioned your glue, I was going to ask. I though I recognized it. I can’t imagine anything else that would work.
