Titebond glue failure question?
I am making a chip and dip platter for a friend. Its a shallow bowl with a haunch in the center for a bowl of dip to sit on.
Supposed to be a quick project to consume some scraps of cherry. I cleaned up the cherry by running both sides over the jointer or through the planer. Glued up what amounted to a round cutting board using Titebond III.
The glue was the tail end of a bottle I have had for an unknown amount of time. I stirred it well and used it. I have to admit the glue looked a little "grainy". I ran the blank through the planer and one of the joints failed. It had been in the clamps for an hour and the temp was good. I jointed the two surfaces and reglued it.
Five hours later I turned it. Used a recess for the chuck. One joint was dead center and it separated slightly. I filled it with CA, but I am skeptical.
I am suspicious of two things. The first joint that failed may have been because I failed to clean the oxidation off one of the faces and the glue had been in the glamps only an hour.
The second thought is that the glue was too old. I may have been too frugal, but this was a "scrap" project.
Any thoughts?
