Glow in the dark inlay
Joe Pack
I'm looking to make a wizard's wand for my grandson. Ideally, I would like to inlay it with a material that would glow in the dark. Any ideas?
Re: Glow in the dark inlay
JKJ does lots of wands and somebody on the Turning forum does fabulous YoYo's. Either should be able to help. If I had one more active brain (Making it 2) cell I could be of more help.
I've made 100s of wands but haven't made one with luminescent inlay. A guy in my club told me about a product he uses. I'll see if I can find it or try to contact him.
I think you can buy luminescent paint
Whether you can buy small quantities - not sure. YOu might try quality paint stores and hobby stores.
Re: I think you can buy luminescent paint
Mark
Rust-o-leum has a glow in the dark paint designed and marketed for use in kids rooms. No experience with it i just remember seeing it at one of the big box stores.
glow-in-the-dark materials
One problem with glow-in-the-dark material of any kind is it needs to be charged with light and only glows for a short time.
It would be tricky to make from wood, but imagine a wand with a hollow handle for batteries and an LED light in a translucent acrylic tip. I haven't checked but I suspect someone has already made these from plastic - if so, salvaging some parts from one might be a good start on one made from wood.
Re: Glow in the dark inlay *LINK*
Keith Newton
If you want an actual light, here is my idea. I bought a light for my compound bow sight that illuminates the fiber optic pins. If you mounted this in the end of the handle, with a monofilament running down the center, this would get the light right on the tip where it would be expected.
I think I’ve seen the fiber offered in lengths of various colors.
eBay has them even cheaper.
https://www.amazon.com/Trophy-Ridge-ATR3SRL-Rheostatlight/dp/B002BIM0CK
John McGaw
Google for "glow in the dark plastic rod" and see what pops up.
compound bow sight light
Do you know the max diameter of that light? If that's a 3/8" thread it might need a wand with a pretty fat handle.
Does the very end twist for the switch or a textured part?
Re: compound bow sight light
Keith Newton
I’ll have to get back to you when I’m back at the camp.
Measurements
Keith Newton
The diameter is 9/16”, and the length not counting the threaded part is 13/16 long. The top 1/2” or so rotates for the switch, and the mid knurled section I guess is to screw in the threaded part. Mine wouldn’t stay in tight, so I glued it with CA which is keeping together so far.
Oh one more thing, is that the light is purplish blue
Re: Measurements
Thanks, that's not as big as it looked in the picture. I might get one to play with.
Re: Measurements *LINK*
Keith Newton
Yea, you ought go for it. I’d imagine you already have the aircraft drill bits for the long deep holes, and at that price, how bad can you go wrong? Ha
Aside from the light, the fibers are more expensive than the light. However, I wonder if a fishing line monofilament would work for this low tech application.
https://www.google.com/shopping/product/9953749238964209512?q=archery+optical+fiber&sa=X&biw=320&bih=454&tbs=vw:l,ss:44&prmd=isnv&prds=epd:4618220724346431734,paur:ClkAsKraX0AGAlIhmsF3IIivqySHvri1nXvfS4lhg6s-vHfOWAMMcnXL1CRk-lDuZWjNEGmAv-sHvHZVkB50QE
fibers and bluish light
The picture of the variety in colored fibers plus your comment that the light is purplish blue makes me wonder if the fibers are fluorescent and the light has a UV component. A bluish UV light can create a variety of colors this way.
I use UV lights to check wood and eggs.
