RO Sander Pad repair?
Tom Norton
I noticed that my PC sander Pad is delaminating. Thought I might try gluing it. What adhesive would you fellows recommend?
Re: RO Sander Pad repair?
I have used CA on sanding pads used on the lathe and it worked well. I have also used E8000 on ROS pads with good results. If you have the same PC sander I do you can buy replacement pads at Home Depot for about $14.
contact cement, but...
Dick Coers
Once they start to fail, they are short for this world is my experience. Better buy a replacement before total failure.
Re: contact cement, but...
Tom Norton
I think you are right about just replacing it. It has given me a number of years of service.
Kneale Brownson
Get it quick before they stop making replacements
Kneale Brownson
I have three PC tools that I can no longer get switches for
Buy replacement, but keep the old one
Tim Greif - West of Chicago
Like Dick said, once they start going, they pretty much keep crumbling. I've replaced two on my PC, but keep the bad one for use with 3M abrasive pads to clean cast iron surfaces with WD40 as lubricant. Gets the iron very clean and the pad pretty cruddy, but at least it's not the one you use for sanding.
Re: Buy replacement, but keep the old one
William Duffield
I have noticed that if you lubricate wet/dry abrasive sheets with mineral spirits on these sanders, the pads delaminate very soon. I used to do this for removing rust from cast iron tables. I therefore suspect that WD-40 might have the same deleterious effect on the pads.
Wade Hartmann
I have two PC RO sanders, and go through the pads probably annually....I was in the middle of a large paid project, and ended up needing another RO sander. I decided to go with a Rigid RO, after doing a little review research.....and boy am I glad I did so...what a difference, and a lifetime warranty. Sorry PC....
