Complementary Routed Curves?
Tom Norton
Years ago when I did a bit of solid surface countertops I created perfect joints by using 1 template and routed both pieces at the same time. They were spaced apart just a bit less than the router bit diameter. I used a router mounted bushing.
Any reason this would not work with curves? I see the idea of 2 templates but thought this might be another way.
Thoughts?
Thanks!
