Clamping table?
Tom Norton
So here is my idea. I am going to fabricate new garage door sections that will be 28"x108". They will be 3/8" ply,both sides, glued to a cedar frame work with polyurethane in between. To glue this up as a unit I am thinking of making a table a bit wider and longer the when the "section" is glue put it on the table with a sheet of 3/4" over the top then have cauls spanning the width to apply clamping pressure. Since I don't have enough deep clamps I was thinking of using Tee Nuts in the table and long hex bolts through the cauls. I could use a hex driver in my cordless drill to run them down.
Thoughts??
Thanks!
