Band saw tires
Band saw tires
Band saw tires
Joe in a Cleveland suburb
Hi all.
I turned on my 14" Jet bandsaw (w/riser) this morning and the bottom rubber tire exploded into pieces. Scared me. I think the tires are about 20 years old. I think that's how long ago I bought it.
I have a WoodSlicer blade in it now. Suppose I should inspect its teeth now.
Anyway... suggestions for new tires?
They seem to run $16 - $30+.
Are they all the same?
Does color mater?
Orange? Blue? Red? Black?
Is there a brand everybody prefers?
Thanks for any suggestions.
Re: Band saw tires
Re: Band saw tires
When that happened to my 18" Rikon I installed these:
https://www.amazon.com/gp/product/B000H685B8
You can also order the same tires directly from Sulpher Grove for a $20 more. That's what I did before checking around.
Excellent tires, much better I think than the stock tires. It took some creativity to get them on the saw.
Re: Band saw tires
Re: Band saw tires
Thanks. I ordered it...
Re: Band saw tires
Re: Band saw tires
William Duffield
Carter tires have always been the standard for quality. They happen to be blue, but the Chinese forgers learned a long time ago to replicate the color of the best in any category in their knock-offs.
When you go to install them, preheating them in a pan of hot water to make them a bit more flexible and using a little dish detergent to lubricate them will help immensely. If you happen to have cast iron wheels, you might consider some other method of heating and lubricating.
