Plywood glue up question
Tom Norton
As I move forward with the plan for garage doors I have a question for you folks! My core will be a frame with 1/4" ply glued to both sides with polystyrene insulation in between. So here is the question. The exterior will be a cedar rail & stile with the fields being 3/8" ruff sawn ply glued to the 1/4" core. It will be run vertical where as the core is horizontal.
Am I setting myself up for a problem?
Re: Plywood glue up question
Gonna speculate
Questions like this always raise red flags about "balanced" construction, although this isn't a typical veneering situation. My concern would not be about grain direction of your two plywood layers, but about whether both sides of this door are the same, i.e., will there be a 3/8" layer glued onto the inside core as well? If not, your construction needs to be robust enough to counteract any warping or stressing you are setting up by the unbalanced construction. I can't think of any way to calculate this likelihood, unless you want to try making a sample. Keep in mind that, with a garage door that has sun exposure or differential temperature conditions (large difference in indoor vs outdoor), you need to consider these factors in your testing as they could affect the moisture exchange or deforming tendency of this construction.
Sorry, can't be definitive. My hunch is that you will be able to get away with your plan without major problems. I just wanted to suggest that you consider things that could be factors. If you can do this without actually bonding the two plywood layers together, I'd feel more confident about it.
Re: Gonna speculate
Tom Norton
I could pin/nail it around the perimeter but some of the "fields will be 20"x 48".
Maybe I will redesign it eliminating the 1/4" ply and just use 3/8" on both sides.
Kneale Brownson
Re: Gonna speculate
Kneale Brownson
I've had three older wooden garage doors over the years, all built as frame and panel designs. The panels were all single layers of approximately (never took one apart) 3/8 to 1/2 inch in framing that is 1 1/4 inch material.
If your goal is to produce an insulated door, why not just glue insulation to the inside?
