Choke Cherry
Choke Cherry
Choke Cherry
Don Wagstaff
I am wondering about this wood, yes in bigger sizes milled up but also in the round as well. Is there any reader who's used this wood?
Re: Choke Cherry
Re: Choke Cherry
I am wondering if you are really talking about black cherry, a common furniture wood. The choke cherry that grew on our farm was a shrub that would not yield any lumber.
Re: Choke Cherry
Re: Choke Cherry
Don Wagstaff
Yes, it's this shrub-version I do mean. What I have in mind is that much like the hazel that grows here can be copiced, that is to say cut back from time to time to generate regrowth, the wood useful in many ways, does this choke cherry give us useful wood? On top of this, many woody shrubberies can give interesting wood even if on a reduced format.
Re: Choke Cherry
no idea
I spent my youth trying to kill it growing in fence rows. Blessed with quality furniture woods like cherry and walnut I never considered its possible utility. I did give a turner some wild plum once and it was so unstable when drying he was never able to successfully use it for a bowl.
Re: Choke Cherry
Re: no idea
Don Wagstaff
Yes, it's this persistence that makes it interesting. If you cannot kill it why not make it into something you love like good tool handles or even a stock for beating off a pesky hound, (have you ever felt the sheer brutality of a dense hazel nut stick in your hands? And let's not even mention the blackthorn) . I realize this is treading on ground at the very fringes of our woodworking experience.
Re: Choke Cherry
Re: no idea
Hank Knight
Don't worry, the fringes are pretty wide around here.
Re: Choke Cherry
Re: no idea
The turning Forum would be more likely to have experience. They scrounge anything. I found that dogwood limbs make excellent chisel handles material.
Re: Choke Cherry
Re: Choke Cherry
William Duffield
Mark Sfirri told us several years ago that if you can find it in sizes large enough to turn that it can be dangerous, as it suffers from ring shake. That means that pieces can easily separate off along the growth rings, resulting in high speed, sharp shrapnel from the lathe. Heeding his advise, I have never tried to turn or carve either choke cherry or pin cherry.
Re: Choke Cherry
Re: no idea
Don Wagstaff
Oh, I normally keep a distance from turning - I probably miss out on a thing or two.
Re: Choke Cherry
Re: no idea
Don Wagstaff
The handle of my dearest hammer is dogwood. Just a little trick I picked up from the old French blacksmiths.
Re: Choke Cherry
Yes, that's its problem
Bill Howatt
I have turned a little choke and pin cherry and as was mentioned you have to be careful about pieces having ring shake. Around here, any pieces that get much over 6" or so in diameter often are starting to decay in the center.
Bill
Re: Choke Cherry
Re: Yes, that's its problem
Don Wagstaff
Ring shakes, so often associated with sweet chestnut. One of the nastiest of all wood defects for sure.
Re: Choke Cherry
I've seen severe ring shake in walnut and chinese chestnut, some in oak and ash. I read that it can affect any species and even now not all the experts agree on the cause.
Re: Choke Cherry
Don Wagstaff
And poplar and robinia, I've also experienced in these. Only in sweet chestnut though do I specifically look out for wind-shake at the lumber yard because it is so known to be susceptible to this problem.
