Veritas - Innovation in Tools
steam box material
steam box material
steam box material
Michael van pelt
my old steam box was made from marine grade plywood but it has disappeared? I have two arms to bend for a bowed arm Morris Chair. will regular plywood hold up? thanks arms are 1 x 6 x 42
Re: steam box material
Bruce, a MN Galoot
I wold think that for a one-time thing, it would be okay. I tried MDF for a project, and it failed miserably. I also use schedule 40 pvc, though I think schedule 80 would be better.
options
You could go with solid lumber, or cutting from pressure treated plywood, or any exterior grade plywood like what is used for subfloors. 3/4" subfloor plywood is cheap
Keith Newton
I’d use exterior grade. Cabinet plywood will delaminate pretty quickly under this harsh condition.
Re: options
2' by 4' panels of treated plywood are available at Lowes. Less than $20. 1/2"
They also have composite wood made of foam core PVC that might work. Don't know how it will stand up to the heat, but you don't need much strength.
And you could line your box either with some sort of sheet plastic like Polyethylene or the corrugated stuff. Might be good to keep the green treatment chemicals off your pieces if nothing else.
And over in the pipe department they may have 6" thin wall sewer and drain (SD) pipe. I used it for my dust collection system. Very small selection of fittings, but you could make a couple of end plugs.
John McGaw
I used schedule-80 4" PVC for mine. Probably overdid it since I've seldom used it but I'd think that it should hold up for years of heavy use.
Re: Doesn't PVC deform when heated?
Hank Knight
I understand that PVC deforms under the stress of steam heat and needs some kind of frame to keep it reasonably straight. Can someone comment on this?
Clifton C
Hank, that brings back memories and a laugh... I had cobbled together a steam box using PVC, turned the end caps, boiler was an old 5 gallon can on a turkey fryer etc etc. The PVC pipe was across two saw horses. Part way thru, it started to sag a little... Then really sag... Oops... Ripped some ply and nailed together a V trough to slide underneath. It's funny now, but was a bit frantic at the time.
Bending PVC pipe
Heat with steam and bend like a well done spaghetti noodle. I make hoops for greenhouse that way.
Bruce, a MN Galoot
Yes, it deforms. I made a trough for the pipe to rest on. I also wrap it in some kind of insulation, like towels or an old blanket, tp preserve heat.
A better choice would be to make a box from cedar boards, but the PVC was more convenient.
Jack Guzman from Maine
My first steam box was pvc pipe. It sagged. I now use solid wood,four pieces of 3/4" pine nailed together. Works great. I've seen pvc steam boxes made with heavier pipe than schedule 40. It helps.
You mean you are not supposed to bend the wood and the PVC pipe at the same time?
Bruce, a MN Galoot
Actually, the PVC bends more easily than the wood.
