Dead band saw
Dead band saw
A.J. Hamler
Dead band saw
A.J. Hamler
My Jet 14SFX band saw died on power-up. Pushed the button, it started to power up for half a second, then died. No amount of fiddling with the switch can bring it to life. The switch clicks fully into both positions, but nothing happens.
The way it died reminded me of a tool drawing too much power on start up and flipping a breaker or reset switch. However, the breaker on that circuit is fine and the outlet is hot. (Tried plugging it into other outlets, too, just to be sure it wasn't a loss of power.) Meanwhile, after scouring the manual looking for a reset switch on the saw, but I don't think it has one. If it does, I can't find it.
One thing that might be significant: A couple weeks ago I hit the off switch after using it. The power was cut and the saw stopped, but the switch didn't go all the way into the "off" position. It seemed stuck between on and off, and I couldn't get it to go fully into either. After fiddling with it some more, it clicked successfully into the "off" position, and then functioned normally after that. I have used the saw a number of times since then without issue, but yesterday it died on power up as described.
I know less than nothing about electricity and fixing electrical things, but based on what happened with the switch a couple weeks ago, my guess would be the switch went bad.
Any thoughts?
A.J.
Re: Dead band saw
Re: Dead band saw
The switch on my Performax sander got to kind of fiddly. I bought a replacement. Having a spare in hand, I opened the original switch. It was packed full of sawdust. I did not have enough fingers and toes to reassemble the switch, so I put in the replacement.
What I'm saying is try blowing dust out of the switch.
Do you have enough electrical ability to check to see if the switch is actually working?
I could be the capacitor. Try turning the switch ON and spinning the upper wheel in the correct direction. If the motor spins up, its the capacitor.
Re: Dead band saw
Jack Guzman from Maine
replace the switch
Sounds like a bad switch. They do wear out.
Re: Dead band saw
Re: Dead band saw
I would start by testing the power from the wall to the motor. That will tell you if it is the circuit, the receptacle, the plug, or the switch. If not experienced to do this safely, perhaps you know someone who can.
Re: Dead band saw
Starter Capacitor
You might check the motor's start capacitor. Not uncommon for them to fail. T.
Re: Dead band saw
Re: Dead band saw
90+% chance it is the switch. Surely you have a friend that could check it and/or replace it if it is bad.
Other items that may have failed would be the motor start capacitor, but with your earlier switch issue it is much more likely it died!
Re: Dead band saw
capacitor
A typical "tell" for a dead capacitor is a hum from the motor when switched on, and as someone mentioned, the ability to start the motor with a push. When the capacitor on my 18" bandsaw quit until I got a replacement cap I started it for weeks by pushing down on the blade with a a piece of wood.
When it had the same problem, I started a Jet mini lathe in a class with a twist of the handwheel. It would run either forwards or backwards depending on the direction of the twist.
Another common symptom of a failed capacitor is an unmistakable unpleasant smell.
Re: Dead band saw
Easy to test the switch
Dick Coers
Unplug the machine, open up the switch box on the machine, do what you have to do to gain access to both terminals with a multimeter. Check the continuity of the terminals with the switch in both positions. That will tell you if the circuit is open and closed with the action of the switch
Re: Dead band saw
A.J. Hamler
Re: capacitor
A.J. Hamler
Nope, no motor hum. And turning the machine on and giving the wheels a spin does nothing.
From what you and others have said, sounds like the switch.
Thanks!
A.J.
Re: Dead band saw
A.J. Hamler
Thanks!
A.J. Hamler
Based on what you've all suggested, it does sound like it's the switch -- especially considering the issue I had with it a couple weeks ago.
I don't know nothin' about capacitors, but switching the machine on and spinning the wheels doesn't "kick-start" it, so it's sounding more and more like the switch.
I don't own a multimeter, so I can't check the switch. Fortunately, Jet has exact replacements of the original switch in stock and they're not that expensive, so since replacing a switch is something I can actually do on my own without electrocuting myself (probably), I'm going to try that first.
Thanks!
A.J.
Re: Dead band saw
A.J. Hamler
Re: Dead band saw
A.J. Hamler
Since there's no motor hum when switched on as John mentioned, I'm guessing it's the switch. I tried the spinning thing with no luck.
A.J.
Re: Dead band saw
Re: Dead band saw
Joe W, Detroit
If it is not the switch, check the overload on the motor. A lot of times it is a little red button on the motor housing that needs to be reset. I the motor got bound up, it may have overheated and tripped the overload.
Re: Dead band saw
A.J. Hamler
Re: Dead band saw
A.J. Hamler
A little red reset button was the first thing I looked for, but couldn't find one. Nothing about it in the manual, either. Besides, the power-down was almost instant -- I hadn't used the saw all day, and the shutdown happened about a second or two after hitting the on switch, so no time for overheating.
A reset button sure would've been nice, though.
A.J.
Re: Dead band saw
reset button
A friend brought a small air compressor to me - dead. I was 10 minutes into disassembling and debugging it with no clear clues when I discovered a well-hidden reset button on the lower side of a junction box attached to the motor. Well!
Re: Dead band saw
Re: Easy to test the switch
Bill Howatt
You can also, after unplugging of course, remove the wires from the switch and connect each pair if more than 2 together as if the switch were closed using an appropriate method.
Plug in the saw and it should run if the switch was the problem. You can also run it this way until the new switch arrives unless it is a safety hazard to rely on pulling the plug to turn it off.
Bill
Re: Dead band saw
A.J. Hamler
Wow -- Easy peasy
A.J. Hamler
Got my replacement switch in from Jet today.
Pulled out the existing switch, removed four screws, attached the leads to the new switch, and remounted it.
Bingo, bango -- band saw works like new!
Hey, does this mean I'm an electrician now?
A.J.
Re: Dead band saw
Re: Wow -- Easy peasy
Yes, print yourself some credentials to hang on the wall.
This is a great opportunity to take the old switch apart and see if you can see why it failed and maybe even fix it. If so, it could be a spare.
