ADVERTISE HERE - FREE TRIAL
Installing furniutre tops
I use a combination of pocket holes, table top clips or simply through bored holes in the framing. In none of these cases is a typical screw with a tapered head for counter sinking ideal.
I blundered into these screws in the McFeeley site. They are #10, square drive and available in ideal lengths- 5/8", 3/4", 1 1/4" ETC. It is hard to find the 100 package size on the McFeeley site though. Screw lengths and packages sizes, up to 6000, are all mixed up on the web pages. Persistence will find the 100 package size. The head is not tall so the screw can be easily buried with a shallow counter bored hole.
I drive them with this arrangement:
Re: Installing furniutre tops
They look very similar to Kreg screws. Washer head screws. Check at Lowe's, I know they have Kreg products, not sure about Home Depot. The washer head design works well in this application and does not have the "cone" a standard countersunk type screw would have and therefore does not tend to split the wood and drive through. Kreg's shorter screws have a different head that works well but I don't like the shape of it as well. Lowes has them in smaller packs, maybe 50.
screw size?
What size are the Kreg's? #8, 10? I like a size 10 for top installation.
Re: screw size?
Took a few minutes to find it, but they are No 8. Don't know if they have any in No 10, but the do make a larger version of the jig.
The screws come in two different versions, one for hardwood and the other for soft wood. The hardwood version has finer threads. The screws are self drilling. The hold very well and have very sharp threads. I drive them with an impact driver and have never broken one. And they don't strip easily. I have used thousands of them. Never a problem.
Hank Knight
Those washer head screws are also good for attaching false drawer fronts to drawer boxes.
Kneale Brownson
Re: screw size? *LINK*
Kneale Brownson
Kreg has six through eight in 3/4-21/2 lengths
Kreg screws
McFeely's screws are hardened
AZ in Colorado Springs
You will NOT cut them with wire cutting pliers (even lineman's pliers with longer handles). They're very strong.
That's a significant difference from hardware store screws.
Re: McFeely's screws are hardened
I don't know if Kreg screws are hardened, but I do know I hit one with a saw blade by accident and trashed the blade. I will look into the MCFeely ones.
