Glue Choice Dilemma!
Tom Norton
Have a project coming up to make 2 overhead garage doors. I made one in the past which faces northeast so it gets very little sun exposure. These 2 are directly facing west.
The first one I used Titebond 3. But on a few recent posts on Architectural Woodworking they had some failure with TB 3 when the temperature (surface?) Got too high.
I am looking for a suggested adhesive. The core of the door will be polystyrene inside a cedar frame with 1/4" exterior ply glued to it to make my substrate. Then a frame and panel on the exterior.
Thanks for your suggestions!!
Re: Glue Choice Dilemma!
Lee Schierer in McKean, PA
I made one out of framing lumber and T-11 siding that lasted for 20+ years with a direct southern exposure. I used regular woodworkers glue. It failed eventually from wood rot, not joint failure.
Lee
You don't say where you live. All the Titebonds soften at high temperature. A door might get hot enough to soften in AZ but no chance in MN. Epoxy or any of the 2-part mixed resin glues won't soften appreciably.
Tom Norton
I live in NE Ohio.
Jim DeLaney, Austintown, Ohio
I'm also in NE Ohio.
I've not had any glue softening problems. I have had paint crazing on a dark colored (South facing) door that was behind a glass storm door, though. Even in January the door got too hot to touch. Painted it white, and haven't had any further problem.
John lucas
West system epoxy. If it's good enough for boats it should be good for a door.
Tom Norton
I will be using polystyrene for the core. Will West System cause a reaction?
