drilling and tapping cast iron
Howard Pollack
Hi- Are there any difficulties or tricks to drilling and tapping cast iron? I need to add a bracket to a planer to attach a dro. Thanks.
Howard
Howard Pollack
Howard
Re: drilling and tapping cast iron
Don Orr
My limited experience was that cast iron drills and taps more easily than steel. Take your time and use a good lubricant.
easiest of any metal
The carbon in cast iron lubs the tools and they cut without binding. As usual with tapping back the tap periodically to clear chips.
My experience exactly. I most recently drilled and tapped a hole on my PM3520b to mount a task light and it was very easy. I understand under some circumstances cast iron can develop hard carbides right at the surface but I've never run into that.
A little can of tap magic is always welcomed
Dick Coers
A little lube always improves tapping, but cast iron is easy.
Hank Knight
I've done it a bunch. Piece of cake, with or without lubricant. Use a sharp drill bit to get a good crisp entry. If you dimple the iron for a starter, don't hit it hard. Cast iron is easy to break.
Don't know that I'd go that far...
Jason Roehl in Lafayette, IN
...but with HSS taps, it's pretty easy. Not as easy as brass, aluminum or soft copper, though.
I had to drill and re-tap a hole in an engine block once. I had a cheap tap-and-die set from Sears. I twisted the tap. So I asked a machinist friend of mine some advice, and he pointed me in the direction of HSS. I coughed up the dough (~$150 vs. $30 for the Crapsman set), and the new tap was like a hot knife through butter.
Jason
Me either....
John in NM
When I worked in a welding shop, we often had to drill out cast decorative parts to fit on whatever the decorator handed us to make. Sometimes they drilled like butter, sometimes they ruined the drill bit before the hole was done.
I'd say brass or bronze drills and taps better than anything else I've cut, either of those get the title
Thanks everyone.
