Bandsaw tire question
Joe Pack
The bottom tire on my Jet 14" bandsaw "popped" a couple of days ago. It is in one piece, but the adhesion between tire and wheel is gone; the tire slips on the wheel. Can this be repaired with a couple of small spots of epoxy or other adhesive, or should I just replace the tire?
Re: Bandsaw tire question
Jack Guzman from Maine
If it comes off easily it is stretched. Replace it. If you do glue it don't use epoxy. It will be hard to remove in the future.
TomD
You can use double sided tape. You get the type you can wet with water or solvent, Then you can wrestled the tire on and spread it out, and after it dries, ready to go. Golf grip tape is good. Fww had an article and the guy glued it down, and then had a jig with a router to grind it concentric. I prefer my method. However, just buying some new tires off ebay is easier all around.
Jim DeLaney, Austintown, Ohio
Just buy a pair of urethane tires, and install them according to directions. No glue needed, and the urethane tires will outlast the originals by several times.
Thanks
Joe Pack
Thanks to all. I took the easy route and ordered urethane tires.
Jerry Roberts
Hey Joe. I had just about the same problem with my Jet 18 in. I had to order new tires from Jet. Google said boil a pan of of water , put the tires in and let it set a few minutes. or might be seconds. They go on easily after that, no glue!
paul in AZ
Second the hot water. My Jet 18 tires went on fairly easily after being submerged in hot water. The hotter the better. Lukewarm or medium hot is a struggle.
