Questin for Mark Hennebury...
John in NM
I'm about to arrange shipping on a Maka SM6P, can you help me with an approximate weight?
Re: Questin for Mark Hennebury...
Mark Hennebury
Call or email me if you need any help with the machine. They are great machines, but are old and can have a few problems, like any old machines.
Re: This place is amazing!
Perfect!
John in NM
Thanks Mark!
I've been after one of these machines for quite a while, available machine and available cash finally lined up :D
Re: Perfect!
Mark Hennebury
The machines do a great job, fast and accurate. A bit of a learning curve, but once you get used to it its a piece of cake.
One of the things that you may have to do is refill the oil in the feed unit, if it is not feeding smoothly. I can guide you through that process, as bleeding the air can be a pain if you don't do it the correct way. Adjusting the throw on the chisel can be a little confusing at first also. Lots to learn.
Anyway if you have never used one before, you will probably have a lot of questions. when it arrives and you get a chance to look it over, call me and i will help you sort it out.
Re: Perfect!
John in NM
I'll definitely have questions, so you'll be hearing from me. I appreciate your willingness to help!
