Walnut slab
Walnut slab
Walnut slab
Dave Dircksen
How would you finish this for a window table?
Re: Walnut slab
Re: Walnut slab
I've used a variety of finishes for walnut - and they've all worked reasonably well.
You might consider using a floor polyurethane. That finish is quite durable and reasonably resistant to light, moisture, etc.
Re: Walnut slab
Re: Walnut slab
Jerry Gibbs
I would stain it, especially a table exposed to sunlight. I have read too much about walnut washing out.
Re: Walnut slab
Re: Walnut slab
John McGaw
Or at least some finish with good UV blocking...
Re: Walnut slab
Agree on stain
Walnut looks terrible if exposed to sunlight for a long time. It turns a straw color. UV inhibitors are only so effective. My preferred treatment is to hit it with a dye stain first, let it dry, and then apply a pigment stain over that. Restoration experts often use a yellow or orange dye as a preliminary colorant, to negate the purple cast of fresh walnut, then they follow up with whatever shade of red and brown they need to match the piece they're repairing. I suggest using water soluble dyes for permanence. The reason I follow up with pigment stain is to add richness, contrast and complexity to the color -- similar to what glazing techniques do -- as dye stains tend to look rather monochromatic by themselves.
My 2¢,
Ellis Walentine, Host
Re: Walnut slab
Pigment stain is forever
Depending on the chemistry, dye stains fade more or less. The "premetallized" stains are best. Pigment stains are usually mineral pigments like iron oxide or manganese oxide. Their color lasts for geological times. I only use pigment stains on my work unless it is mahogany.
For reasons I don't understand just oiling walnut with linseed oil produces a lasting "walnut color". I have 60 year old gun stocks that are the same color as when they were first oiled. By contrast, factory finish stocks have faded to the yellow color walnut fades to.
Re: Walnut slab
Finish
Here in TN a typical varnish will last a few years in a southern exposure window. Marine varnish will last a lot longer but I find it dark and ugly. Any of the oil based varnishes will yellow with age which is not necessarily bad on walnut. Automotive clear coat will stay clear but I don' t know if the wood beneath will be affected by light, degrade and release the clear coat. Most times when clear coat falls off a car it is because what is underneath got degraded.
Re: Walnut slab
Oil
paul in AZ
I have used boiled linseed on walnut and have not felt the need to play with stains. A coat or three of BLO intensifies the walnut color and pops the grain. Final finish is typically an oil varnish.
A table I built 35 or so years ago still has a good walnut color. A harpsichord case still has as dark a walnut color as it did when I built it ~45 years ago.
Re: Walnut slab
ebd
Re: Oil
ebd
Were those items sitting in a sunny window? My walnut pieces that aren't directly exposed to sunlight have stayed the same color. They are in light, just not direct sunlight.
Those pieces that sat in direct sunlight bleached out to about the shade and color of teak. This is in central NY where the sun is never very strong and in windows that were not directly south.
Re: Walnut slab
Re: Walnut Finishing
I've had several walnut pieces in a bright (south facing) but not direct sunny room for 15 years with no change in the color.
Finish was/is Watco with some pigment, followed by dewaxed garnet shellac, and topped with waterborne acrylics, either lacquer or poly.
Re: Walnut slab
Clint Searl
Re: Walnut slab
Clint Searl
Watco Red Mahogany under Varathane water borne floor finish.
