Laminated door question
Someone has asked me to remake a cabinet door. The door is about 20" by 18" and about a 1/2" thick. It has what appears to very thin plastic laminate (Formica?) on both sides. One side is maple looking stuff and the other is nondescript brown. The edges are square and brown. Oddly, they used the maple side as the inside. I know that because it has Euro style cup hinges drilled into that side. One corner is broken off and the guts of the door is particle board.
Any thoughts? I suspect the doors were cut out or larger sheets that were factory laminated. I did not know you could install cup hinges on door that thin. I am considering using MDF and laminating vertical grade maple Formica on one side only. And I will let the painter stain and finish the other side in brown.
I have checked around and cannot find factory laminated sheets. The problem is they want one door and I would have to buy entire sheets of laminate and substrate.
This reminds me of the laminated the table top that came up the other day. Can I cover one side only? It will warp won't it?
