Ornament hanging wire
All grover
Need a source for 6” brass c type hanger to be used with a wood base
All grover
Re: Ornament hanging wire *LINK*
John McGaw
Not really sure what you are trying to do. If you want a hanger to support an ornament on display then you could probably buy the 7" version that Amazon sells and cut off the wire loop that it comes with. They describe it as gold but that would be suitably brass-looking for me.
https://www.amazon.com/Darice-17148-Ornament-Hanger-7-Inch/dp/B00DD3XIW8
Dick Coers
Are you talking about a table top display? I bend my own using bare brazing rod.
Paul G rover
It’s 6” rad. (Half arch) with a hook at the top and a 1/2” bend at the bottom to go into the wood base. They were supplied by BARD’S, but they no longer sell just the wire hanger,you must purchase the base with it. I make these for a hospice group,they hang a bell on it.thanks Paul.
John in NM
That sounds really easy to make, I'd do as Dick suggests and find some brazing rod at the local hardware store. Failing that you could look for some annealed brass rod from K&S, it would bend well without too much spring back. You just need a large form (like a big bit of pipe) for the large bend and pliers or a bending jig (like the pic below) for the tight bends.
Please tell me about the hospice group
Dick Coers
Do they give them to family, or directly to the patient? Is it a special program, or just something you personally do? My Mom is in hospice, could be something I do this holiday.
Re: Please tell me about the hospice group
Paul Grover
I think it is a fund raising they do around the holidays.
