Tinting or Dying Lacquer
Stuart Johnson
I'm building a red oak bookcase and would it it to have a brown finish. Can spray lacquer be tinted or dyed? If so what is the best way?
Stuart Johnson
Re: Tinting or Dying Lacquer
The acrylic lacquers, waterborne finishes, can be tinted easily with Transtint concentrates. I use them to blend a room's "new" piece with what's already there, and to blend the color on various parts of a piece made from cherry.
Solvent lacquers will require oil-compatible dyes. Check with M.L. Campbell for information.
They make tint base lacquer
Dick Coers
Just go to a good paint store and they will tint an opaque lacquer, no a clear. If you aren't talking about doing it yourself.
John in Lutz
I tint blond shellac with transtint. For color balancing I spray with a touch up gun or air brush. Then you can spray clear lacquer over it.
Ditto - Tinting or Dying Lacquer
Henry (Raleigh NC)
Ditto. That's my choice as well - tint the sprayed shellac to get color right, then clear coat with lacquer.
Henry
Stuart Johnson
Hadn't thought of tinting shellac then clear coating. Thanks for the tip.
A contrary view
Commercial furniture is finished as you propose. The soluble stain is sprayed over the piece, made of randomly assembled wood pieces of different shade, and it all comes out nearly the same shade, for better or worse. The finish on plastic wood look-alike is prepared to look like this uniformly tinted real wood. I find the effect boring and I associate it with cheap furniture. This coloring is not to be confused with spot tinting sap wood and other problem areas to lessen contrast or blend new wood with antique.
I prefer oak finished with a pigment stain that accentuates the porous grain, see example in picture. This approach does demand perfect staining or poorly sanded areas will suck up stain and darken.
