Re: mortise bits *LINK*
John in NM
I've never seen the inexpensive ones sold as anything but a pair, but the Japanese Star-M & Nakahashi bits are available separately (same manufacturer, different lines).
A few companies import the bits, including Lee Valley and Woodworkers Supply, but Woodworkers is the only one I've seen who sells the augers separately.
These are expensive tools though, might not be worth it just to avoid some sharpening. I've touched the auger up with a small triangular file for the cutting edge and a stone for the spur. Sharpening shops can usually do these augers too.
https://woodworker.com/14-mortising-chisel-and-bit-set-mssu-123-881.asp?search=Mortise%20Chisel%20Bit&searchmode=2
