Is there a wood that does not encourage rust?
In the not distant future I will be getting a nice dovetail saw. I was considering storing it in a wooden "sheath" to protect the blade and teeth. What wood would you use, or would you use wood at all?
Re: Is there a wood that does not encourage rust?
Don Evans
Not sure what wood would be non reactive but here is another solution. I would definitely stay away from high tannin woods like oak. Maple probably best maybe poplar but I'm not sure of it's tannin content either.
Take a look at this:
https://www.toolsforworkingwood.com/store/item/GT-SBG/Saw_Blade_Guard_-_5_Feet_long#reviews
You can also buy round tubing at hardware store that would work. Problem with that is how to keep it on the blade good enough. The product above appears to be flat so I guess it hugs blade to keep it on.
How about splitting a bike inner tube?
Why complicate matters?
Gary Smyth
Buy a couple of packets of desiccant and not worry about a box for a saw. The packets are relatively inexpensive, and safe, and can be recharged. The kind used for gun safes are easy to find. Most any container or drawer will work -- for that matter a fine film of sewing machine oil will work and can be wiped away before use.
Dick Coers
I would wrap it in VCI (volatile corrosion inhibitor) paper before sliding into the sheath. I'd suggest basswood.
William Duffield
Mine are made of baltic birch plywood. You could squirt some camellia oil (or whatever oil you wipe on your saws and planes) in the kerf.
Yonak
I cut one out of a scrap piece of poplar for my Nobex mitre saw blade 20 years ago and I haven't seen any rust.
Just wax.
Just use wax on the metal. I rub on some Renaissance Wax, and then hang up the saw in a till. This works well for me, and the saws are easy to get to.
ebd
ebd
I don't sheath my saws but I made sheaths for all of my very fine (and expensive) kitchen knives from Coroplast (corrugated plastic). You just cut it to the appropriate size and slit the corrugation between the sheets and slide in the thing you want to protect. It holds tightly, is light and tough, inexpensive, and won't cause rust.
Clint Searl
Paulownia
