First dovetails....
First dovetails....
First dovetails....
Tonight I used the dull decrepit saw I mentioned below and cut my first hand cut dovetails. I have been intimidated by dovetails since high school shop.
I cut them in some 7/16" poplar about 4" wide. Did the equivalent of one corner of a drawer. Took about 20 minutes. They were not pretty, but Bill Tindall is correct, that joint is way over Engineered. In spite if being pretty ugly it is very strong.
I need to get a better saw or sharpen the one I have and gather my better chisels and get them really sharp. And practice. And practice.
Anybody know the any magic?
Re: First dovetails....
Let there be magic ..
Hi Barry
Several years ago I developed a method of marking out/transferring marks using blue tape. It has been refined a little over the years. The more recent pictorials I have done are below. These also include techniques for sawing, waste removal and accuracy.
Through dovetails:
http://www.inthewoodshop.com/Furniture/ThroughDovetails3.html
Half-blind dovetails:
http://www.inthewoodshop.com/Furniture/HalfBlindDovetailswithBlueTape.html
You also would benefit from a dovetailing vise, also referred to as a Moxon vise. There are lots of variations. This is mine (old picture, old bench) ...
http://www.inthewoodshop.com/ShopMadeTools/MoxonDovetailVise.html
http://www.inthewoodshop.com/ShopMadeTools/ModsfortheMoxon.html
John McGaw
The magic is to repeat the process at least 100 times and to critically evaluate the results after each, applying the knowledge gained to the next try. Pretty much like most other things in life.
AZ in Colorado Springs
Some years ago, Christopher Schwarz wrote in Popular Woodworking to cut a set of dovetails every day for 30 days, using whatever scrap you have on hand. I did that. You get to experience different hardness of woods, different grain patterns, the sizes (both width & thickness) will vary, etc. It was very instructive.
Just make sure the scraps are squared up when you begin a set of dovetails.
Very clear!
Howard Pollack
Thank you Derek, this is the best tutorial on dovetails that I've seen. Clear with enough detail to be useful. -Howard
Tony - Memphis
Barry, I'm about a half step ahead of you. One of the things that stood out to me on Derek's instructions was the 'baseline wall.' One my current project, I made a small drawer and had a rough go of it with the dovetails. One thing I noticed when I was looking (evaluating as mentioned above - very critically), was that I had gone past my baseline. I followed the common methods, but somehow went at it a little too hard. So, I like the idea of creating that 'chisel wall' first. I've seen the technique around and thought about trying it.
The other thing I learned was be consistent with your marking tools and techniques. You will correct to those and hit a groove. If you change them, then you have to re-adjust. The initial groove will be hit without thinking about it really.
One last thing, I can't see anymore! When I figured that out and got some 1.5x and 2.5x etc,. things did get better! Task lighting helps too.
Does any of this mean I make good dovetails? No. I have been lucky a few times! In a class that I took, the instructor said use soft wood for the sides and make the dovetails a little on the tight side. That worked! I was using walnut and pine.
Good luck!
Tony
Jesse Cloud
Barry,
I want to pile on to what Tony brought up about needing to see what you are doing.
I have a magnifying visor that is hinged. So when doing basic stuff, I have it angled up and out of the way. When I'm doing the close up stuff I angle it down and what a difference!! That tiny bit of schmutz in the corner looks like a pebble! Using that (or reading glasses would work too) has really improved my work.
The other thing about fading vision is that its hard to tell whether a shoulder is 90 degrees or not. A good gauge helps a lot and when those shoulders are 90 degrees its amazing how much better and easier things fit together. Starret makes a tiny square, but it would be pretty easy to make one in the shop.
Not a master dovertailer, but getting better with practice!
Jess
Don Stephan
Another suggestion would be to make up 10 or 15 lineal feet of perhaps 3/8" 3" or so wide poplar (or similar easy working wood) so you have plenty of practice stock the same size. Later you can start combining different thicknesses, for example a drawer front and side.
Thank you all for the encouragement & suggestions
Keep them coming.
William Duffield
Another source for a dovetail square: http://www.sterlingtoolworks.com/dovetail-square/
