Got drawers built and rough fit. I build so the drawer just fits or not quite fits the opening.
When the glue is cured, I rough fit so it goes into the opening. The whole affair then sits a couple of weeks to do what it is going to do and then I final fit by planing where needed. Finally the drawer is shellaced and waxed.
Bill, I usually dry test the drawer for fit before glue up, then glue up and fut the drawer to dry in the drawer recess. It will not run smoothly, and I later plan to plan it to a better fit, but at least it is assured that the drawer takes the shape of the recess. I am not sure if you do this, or let the drawers dry outside the chest? Can you comment?
If I am understanding, after the initial glue grab you remove the clamps from the drawers and insert in the openings, so while the glue is curing the the drawer will take the shape of the opening? Interesting approach if I understand correctly.
I was going to follow up with a post on dovetail layout and gluing up a drawer. So, will comment in detail later. Large cases can wind up not perfectly square and curing the drawer in place is the way to accommodate this situation. The case at hand turned out near perfect (luck) so squaring and curing external was an option. Curing in place does get the drawers out from under foot while work goes on.
Bill said, "Curing in place does get the drawers out from under foot while work goes on."
Yes, that is real problem in a small shop!
[url=https://flic.kr/p/236xZ8F][/url][url=https://flic.kr/p/236xZ8F]IMG_1305[/url] by [url=https://www.flickr.com/photos/158680038@N03/]Hank Knight[/url], on Flickr
