Advise on making cutout for sink in walnut Block
Alan Young
Alan Young
My son is installing a glued up walnut slab counter top in his kitchen. I am going to help him cut out the opening for the sink which will be mounted underneath the counter and have a 1/4" reveal. The sink came with a template. I want t know what the best method/tool(s) is/are for cutting out the profile--The counter top walnut is 1.5 inches thick-Thanks
Re: Advise on making cutout for sink in walnut Block
First thing.
Virgil Johnson
Finish the job with better beer...:-) Rough out with a jig saw. Make a template for a flush trim bit router bit to follow. Its worth the effort to make a prototype top out of pine just to check the reveal. Looks like an expensive top.
It would seem to be a trivial task with a saber saw and an aggressive blade. I just cut 64 feet of 2 x 12 yellow pine stair stringers with one. It was a bit slower than a skill saw, but I am terrible with a skill saw.
I predict disappointment with the sink project if the kitchen is used much. Wood , water, and use don't mix well.
Jack Guzman from Maine
Jigsaw
What Virgil said and score the line with a sharp blade where you will be cutting across grain. It will prevent lifting splinters.
PS
The blade will make a huge difference. You will want a blade designed to cut aggressively and a modern saw that has a front to back action as well as up and down....makes a huge difference.
Re: First thing.
Tom Norton
When I did a Corian top I did make an exact template out of plywood to pattern route for the sink. Do a trial on plywood to make sure you like the margins.
And
Cut from the underside to prevent tear-out of the upper edge.
Finish the cut edge and underside around the opening with a thin epoxy like Mirror Coat or Mirror Glaze bar-top finish to get it to soak into the end grain. Plan on several applications mixed in small batches.
Kneale Brownson
Wooden counters
Kneale Brownson
I've had several sinks in wooden countertops, one for more than 40 years, without experiencing water/wood issues. The important thing is sealing the wood well.
Jim DeLaney, Austintown, Ohio
Re: Wooden counters
Yeah, but it's an under-mount sink, and there will be a lot of (water absorbing) end grain exposed. I predict failure in a relatively short time.
Epoxy
is the answer.
Lots of "high end" sinks made from wood, especially segmented glue-ups, that are costed with epoxy and hold up very well. Some I seen in "galleries" carry 10-15 year warrantees.
Must not have kids
Dick Coers
When I see this kind of application, I always think they don't have kids and they are a much more meticulous cleaner than I am. Who knows what would grow under that 1/4" reveal. Not going to be easy cleaning that without some chemicals that will not be kind to wood!
I would make an outside template out of MDF or plywood and smooth it and get it exactly the way I wanted and then pattern route it. With and outside pattern there's almost no risk of a run away and over cutting the hole.
Where is the reveal? Is a 1/4" of stainless exposed or does the walnut overhang into the sink?
If the walnut hangs into the sink I would try to figure out a "drip edge".
I would seal it with epoxy as Mark suggested and I would bed the sink into pure silicon.
I'd make a cutting board out of the cutout.
Alan Young
Thanks for all the comments-
Alan Young
We are formulating a plan.....
Re: Epoxy, Not all the 2¢
Keith Newton
Sorry Im so late gettin in on this.
First I would saw, then template route the final shape.
Next, I would use a penetrating epoxy as the first coat, even warming the wood so as it cools, the air contracting in the cells draws it deeper. Smiths is slow setting, so you can brush on more as it soaks. You don't have to have it fill all the space in the cells, but when it fills the cell walls, it inhibits it from ever soaking up moisture like would happen if you had a ding with just a top coating.
I've mentioned using it on my Eastern Redcedar island top down at my cabin. That wood is too soft to use with just a finish, but it really soaked up the epoxy and is as hard as your Walnut, if not harder. Another benefit, is that it has stayed the deep red, purple and gold instead of turning tobacco brown like the legs and drawers.
I only used one coat of wipe on poly after a fine sanding, which looked like about 8 coats of any wipe on finish.
Ive also used it on some tables that had glasses full of ice left on it overnight which would have left a circle on most other finishes. Another time, I used it as the first coat to seal a table top, then sprayed with SWP pre-cat lacquer that while I was away for a long weekend, my roof leaked. Two days later when I returned, water was standing on about two square feet, but showed no ill effects.
It seems expensive, but I buy the 2 gallon kit, and use it for lots of projects, and this top is surely one I would use it on if I were doing this top.
I think you can get it from Jamestown Dis.
TomD
My experience with epoxy is it never really wets. I have mostly used the boat brands, but lots of others, though never that deep penetrating rot stuff. If you put a piece of wood in water, eventually it is fully penetrated, saturated, in water. At one point I did extensive tests to see if I could these deep penetrating epoxies to even penetrate .023" of wood to allow me to use this veneer product that needed epoxy coating, but if I could get the coating to penetrate .023 thou, it would have been a structural game changer. Nothing worked, that one would normally do, maybe pressure would have worked, but it was beyond the volume of the project to provide pressure. Of course you can suck it into pores as suggested. But through the cells is hard to do with large objects. Well for me.
