I'll start by stating that I am not a pro woodworker. Probably could be but that would make it work! I have built five kitchens using the 32 mm system using Blum hardware. I love it except the hinge mount plates do not accomadate for the 5mm screw used to mount same. These are frameless cabinets using the predrilled 5mm holes spaced 32mm apart.
I have to drill out every hinge plate with a 1/4" bit. Not that difficult but still a PITA. I got to thinking maybe I'm missing something simple here. Any tips would be helpful.
Bob, It sounds like you are using the plates for wood screws.
If you are boring the 5mm holes then using the 6mm system screws, the easiest method is to get the plates with the pre-mounted screws. You can get them either in forged, or zinc die-cast. Try these numbers, 175L8100 for 0 height, or change last two numbers to 30 for 0mm, or 90 for 9mm high.
The only time I've had a problem with remounted screws is when trying to screw them back to back on a bulkhead with through holes. The screws art too long, so the second side will bottom out before getting tight. You can however get shorter screws then change them out for those few occasions.
