Rust proof cast iron tops
Jack Guzman from Maine
I have been processing green wood for chair parts. I use the tablesaw to crosscut to length, the bandsaw for various jobs and the lathe to make blanks into legs and other chair parts. The problem is at this early stage the wood contains much water. The problem is mostly at my lathe. I coat it with top-cote but it still stains from water reacting with the iron. Is there something better to coat the iron with? I wipe the tops after use but sometimes things get left. For instance,I have cut a recently turned round on the tablesaw to get a square end and forgot to pick up the cutoff piece right away. The result is a round spot of rust on my top . It doesn't take very long either. So,I need a solution. Any ideas?---Jack
