Re: A question for experienced dovetailers
Sgian Dubh
"So one whack on the 6 mm, use that "recess" to register half the 10mm and give it one whack, same with 16 mm and so on until you are using a chisel that pretty much spans the area between pins? Sounds interesting."
Not quite as you describe Don. Derek's photos in a later post serve as an illustration. He's cut close to the cutting gauged shoulder line (aka base line with some people). How far this cut is from the shoulder line dictates the position of the first cut with a narrow chisel, but the idea is to pare back to the shoulder line with it, whether in one pass or several all depending on how much material has to be removed and the hardness of the wood.
One thing I forgot to mention is I rarely use a mallet in final paring like this. With the piece lying flat on the bench, on a sacrificial board, e.g., MDF, I hold the chisel as if it's a pen or pencil in my right hand (I'm mostly right handed) for precise positioning, and my left hand wrapped around the chisel's handle, with my thumb resting on the end of the handle. Then I simply lean over, tuck my left thumb into my right shoulder and use my body's weight to push the chisel through the wood.
Once the opening is created I grab wider and wider chisels to extend the opening to the corners. I generally only cut from one side, i.e., the outside 'show' face relying on my ability to judge perpendicular to that face for a clean cut. I'm not fond of paring from both sides because it's more time consuming than I like. Dovetailing is a bit of a boring job so I prefer to get through it as fast as I can.
"... do you have a way to avoid breakout in the middle of the board, or just ignore it?
Use a sharper chisel, take smaller cuts, don't aggressively whack a too dull, too wide chisel with a mallet. Slainte.
