Stanley-Carter J5 Power Plane Kit
kgschlosser
I would like to know what may be missing from this kit.
Pieces I know are 100% complete.
J5 Power Plane
Grinding attachment
Grinding arbor (with original emery wheel)
Benchtop clamp
Zerk Grease Gun
Steel carrying case, with no rust, original wooden tool supports, glued on padding on tool case lid.
Documentation I have
Original typed instructions with exploded parts diagram and parts list with original parts prices.
Cutter brochure
Stanley-Carter Tools brochure
Yellow warranty/inspection tag
I have 3 cutters. one on the tool and 2 more with what seems to be original canisters. I am pretty sure the 2 cutters with canisters are not part of the kit.
The tool has the original cord free from hardening and cracking/splitting. I do not know if the plug end is original. it looks as tho it may be a replacement end but it would be an old one. (cardboard cap, missing)
I found this tool at a recycle place along with a router kit (which is in the same condition and seems to be complete) from Stanley-Carter at a ReStore retail outlet.
what I would like to know is:
Is anything missing?
what would be the value of this kit?
I have attached a link to a photo of the kit with all parts that have come with it.
Sorry about the link I wanted to keep the original resolution of the image so you would be able to zoom in to identify the parts.
Re: Stanley-Carter J5 Power Plane Kit
MartinMJ
Looks like the father or grandfather of the Port Cable 126 planer. I had one and sorry I sold it. Mine PC 126 did not have all of those accessories. The cutters seem to go for $75 to $250 depending on new or sharpened. How much did you pay for this? One refurbined PC 126 I ran across is $650.
I had one almost fifty years ago that somebody gave me. I don't remember what happened to the plane kit part of it. I still have the router and use it occasionally. I may have the cutter. Never occurred to me that it might be a collector's item. Sorry I can't help you, but you have peaked my curiosity.
kgschlosser
I paid 10.00 USD for the J5 kit and 10.00 for the matching router.
I did dismantle the unit today to clean all the sawdust and hardened grease out of the bearings. the spring loops for the brush seats are in prefect shape as well as the insulators. There is quite a but of meat left to the brushes
the woven insulation on the wires inside is in tact and actually in really good condition. The trigger mechanism and switch work perfect along with the trigger lock. all of the adjustments are in working order. The cord has been replaced. but it was replaced a really long time ago. it has the rope pull cord in it to strip the insulation back. the person that replaced the cord used the original eyelets to attach the cord to the trigger which is really good. There are 4 missing screws one for the cap on the top of the trigger handle and the other 3 attach the back plate adjustment bracket to the back plate. the only cleaning i did was removing the sawdust and solidified grease from the motor internals. I did not touch the patina at all. It was a challenge to get the Zerk fittings cleared and in functional condition as well as the grease gun.
I assembled the grinding attachment and tested it out. It sharpened up one of the spiral cutters to almost razor sharp. There is a bad bearing on the auger for the grinding attachment it works but makes noise. It looks like a sealed bearing. Not sure if there is a way to get some oil/grease into the bearing. I think I am going to try and soak it in some oil overnight. maybe it will get inside.
I gave it a run on a piece of sixty year old White Oak. It removed material just fine. i didn't have any chatter marks (probably because the thing is so bloody heavy). I am not an avid wood worker and I am not sure what the quality is supposed to be with a planer. but I would say some light sanding was all that would be needed afterwards.
I will say this. for 18,000 RPM's this thing is really quit. not like the tools made today. and I love the smell from the lacquer coating on the windings, you only get that with old tools.
I would say it is 100% working.
kgschlosser
I did want to give an update on this.
The bearings on the end of the shaft for the cutter and the shaft for the grinding wheel did suck up oil. I am happy about that. no more bearing noise from the grinder. That is why i decided to do the cutter shaft as well.
I have run approx 1400 linear feet of 1.5" wide White Oak T&G floor planks (almost 50 years old) through the planer. It worked like a charm.
The planer comes with a clamp that attaches to the motor so you can spin the planer upside down and attach it to a bench for sharpening the cutter. I used this clamp to hold the planer upside down. I built a frame that went over the top of it that held 2 large casters, the casters are rated for several thousand lbs so that gives you an idea of the size. with the use of shock cord (3/8" bungee cord) to pull the casters against the deck on the planer i was able to turn the planer into a feed style planer. granted it was not an automatic feed, it still did the job. it took me a lazy 2 days to do all of the boards with stopping for rain, and also cutter sharpening. then another day to run them through a 16/32 Jet drum sander a few times. The boards came out better then I thought they would. The boards probably only had maybe 2 sandings left if I used one of the large flooring sanders on them. because of the heavy grit used so the paper would not clog. Going the route i did and pulling the flooring up and planing/sanding in a controllable manner I removed not even enough material to fill a kitchen trash can 1/3 way.
Plus I now have the added feature of no wavy gravy flooring or over sanding near the walls. everything is back to being exactly the same height. as if they were just purchased.
no poly for this flooring when i lay it back down. some stain and going to oil it. Hopefully this will be the last time this floor needs to be refinished in my lifetime.
I did have a single question. The original installer had done a horrible job of laying the floor. there were massive gaps all over the place. and most of the nails didn't even hit the joists (explains the gapping). the old nails were spiral nails i believe they were iron. very difficult to bend. so most of the nails pulled out and they are pin straight. The wood is old and most likely has a much lower moisture content then when it was first put down. I live in Colorado with a very low humidity. I am thinking the boards will split if i use a pneumatic flooring nailer on them or if i hand hammer new nails in. will i need to pre-drill? should i use something like a composite decking screw (small head) instead of the nails? can i use a pneumatic floor nailer?
Let me get this straight in my head....You removed and de-nailed hundreds of BF of white oak flooring, ran it over a 60 year old powered hand plane and want to reinstall the flooring?
Were the nails you removed cut nails? Square tapered shanks? When I was kid, old timers used cut nails and hand drove them into the flooring.
You should look up one of the installation guides for oak flooring. NOFMA (National Oak Flooring Manufacturers Association) would be a good start. I used to do Expert Witness testimony on hardwood flooring and the guidelines are a tedious but worthwhile read.
From what you said and as I recall.....
The gapping in the original job was probably caused by bringing the flooring into the house and installing it before it had a chance to acclimate to the local conditions. Colorado would be very dry and new flooring may have been too wet for the local conditions. If you have kept the flooring in the same moisture content as when you removed it, it has had plenty of time to acclimate by now, assuming you did not move it into a moist environment to work on it.
What is the subfloor? It affects the nailing. If it is sixty years old, I assume it is either diagonal sheeting or actual plywood and not OSB or Wafer Board, but from your response, I don't know and don't know how old the house is.
As far as nialing goes, learn about Nail Pops. Nails tend to get pushed back out by seasonal swings in moisture content in lumber. The roofing industry "solved" the problem by insisting the nails be long enough to drive all the way through roof sheeting. The drywall industry solved or reduced the problem by using shorter nails with ring shanks and ultimately screws.
IIRC the flooring industry wants you to nail through the sheeting but, NOT into the joists. Nailing into the joists gives the joists "purchase" on the tip of the nail and may allow it to push the nail back out. I know this is hard to accept, but the drywall industry tried longer nails and it was a disaster, the studs and joists squirted them back out and it actually increased the number of nail pops.
I would use an air actuated flooring nailer. The nails are thin and wide, and sawtoothed on the edges only. I would stay back about 3 to 4" from the ends and nail about every 8" along the edge.
The floors I have laid over plywood, I did not use 15 lb. felt or any other underlayment. At the time I was convinced any cushion under the floor would lead to squeaks. I have laid about half a dozen floors that way and they don't squeak.
Also, be sure your subfloor is clean and as flat as you can get it. Also check it for loose nails and screw it down tightly to the joists.
