Repairing a crack/split in wood
Occasionally a crack will show up in a place that would not be fatal if it could be glued back together. The problem is how to get glue in a crack- Dental Floss.
Put a glob of glue on the outside and pull it into the crack with the floss. Then clamp.
You can see the effectiveness of this procedure in the picture. Glue has squeezed out where the crack is exposed on both edges, even to the bottom of the crack.
