REAL MILK PAINT
Cutting a large cone
Since I did the cone in two parts it turns out I was able to cut it on the bandsaw. I took my table saw miter jig and rigged up a large fence. Cut the bottom off. Then changed the angle and cut the top off the big cone. I used a sort of Garrot technique to hold it. I ran string around the narrow portion and then tightened it from the back with a dowel like you would tighten a garrot. Worked great. Then I mounted the smaller cone and cut it to fit. Glued the cut off from the smaller cone to the middle cone and trued everything up. Now it's ready for the shelves and base when I find time to do it. I plan to paint this column so cutting and gluing seemed like the best option.
Re: Cutting a large cone
Yonak
Cool project, john. It looks great. What do you plan to do with it ?
Don Orr
Nicely done, but your knowledge and skill with a garrote is a little disturbing. ;)
John C Lucas
Its going to be a cantilever shelf.
John C Lucas
Meant to say tourniquet. Must have been thinking about the plumber who ripped me off.
..Can't wait to see it finished.
John McGaw
Try as I might, I can't get my head around the idea of "cone" and "cantilever shelf" going together. Your really need to post images of the completed project.
