Anyone used Plastic Lattice around their deck?
A friend wants to put plastic lattice around their deck. What do you think?
I am suspicious that it is too flimsy and may sag in the heat. Anybody got experience and a thought?
Re: Anyone used Plastic Lattice around their deck?
Kneale Brownson
May also get brittle and break. I'd think wood lattice would be more substantial and just as easy to work with. I usually put it in a frame.
Tom Dunlap
I used it as skirting a few weeks ago. Certainly not enough time to know about sagging. Installation calls for oversized holes and large flat head screws 24" apart to accommodate expansion
On a couple of places the deck posts were more than 4' apart. I hung 2x4 posts from the outer deck joists. Then I screwed the lattice to them
Paul aleuba
I’ve not had a sagging problem. It is stapled liberally to posts about 8’ apart. It is also stapled to a 2x2 vinyl coated board along it’s length on the ground behind it to keep it straight, I suppose.
I have had trouble with it collecting green algae where it’s in the shade. The algae comes off pretty easily with a sreong hose blast, but I don’t like the looks of it between hose blasts when it builds up again, mostly when it’s very humid here in the Mid-Atlantic.
Paul in Hunt Valley, MD
JohnV
I've used it on two different homes under decks about 2" high. One was installed 12 years ago. I used self drilling rubber grommet siding screws into the rim joists and the support posts about 6' apart. Screws about every 15 inches. no sagging or fading in that time or brittleness in Missouri heat and cold. full sun on the west . easy to work and cut on table saw. Easy too keep clean.
CJ in MPLS
The brittleness is a real problem. Solarization of the plastic due to UV makes it very likely that little Johnny's soccer ball is going to put paid to the lattice pretty easily. It will do well for a year or two though.
dlwurscher
I have had it (White) around my deck now for at least 10 years with
no problems what so ever, it get's western sun here in AR, so expansion
was a considerstion. I enlarged the mounting holes, (top & Sides) and left the bottom edge free.
