ADVERTISE HERE - FREE TRIAL
Domino Hack - Built a Greenhouse
William Duffield
I just finished a small woodworking project, mostly using power tools (bandsaw, Domino and belt sander) and some finish work with files and sandpaper. I need a small terrarium for starting some seeds. I had just emptied a gallon size jar of dill pickles from Costco. I can get more surface area if I set it on its side, but I don't want it to roll off the bench. I measured the diameter of the barrel, and cut two supports, with feet, and tied them together with stretchers made from long Domino stock. I clamped both feet together and cut the mortises through both at the same time, insuring the stretchers would line up. I agonized a while over which kind of wood to use. My bandsaw begged me not to use ipe. Since it will spend the summers outside, I made it all from a couple of species of African mahogany: sapele and sipo.
I could have gotten it done a lot quicker, but for some reason I felt the need to fancy up the lines and smooth off the bandsaw marks, bevel the edges, and put some finish on it. I also had to make a pattern, in case I ever wanted to make any more of these. It's finished with beeswax and mineral oil. It's filled with potting soil, and the seeds are working on germinating.
Re: Domino Hack - Built a Greenhouse
Keith Newton
William at first glance I thought you were starting to build a ship model in a bottle. Maybe this will work into that on down the road. ha
I may have to get back to growing some sprouts too. I used to do that, and love them on a good sandwich or salad.
Last weekend before leaving the cabin, I noticed chanterelle mushrooms were starting to pop up out along the edge of the yard, we had had 5" of rain down there, so I'm hoping to gather a few bushels to dehydrate, vacuum bag, then freeze.
William Duffield
You don't build a ship model in a wide mouth jar. Where's the challenge in that? :D
The Domino is a fairly recent addition to my arsenal. One of my impulse purchases is about a thousand sticks that look like they might be 16" long dominoes in maple, but they are 3/8 thick and not 10mm. They are just a tad loose in the 10mm mortices. I have been trying to think of a good use for them. (Slats in a headboard, slats in a side table,....?) They would have worked nicely for your application. Nice job and thanks for the inspiration.
Very creative!
William Duffield
You might want to sit down before you open this link. :)
https://www.senecawoodworking.com/products/3-8-domino-cutter
You could buy a lot of Festool 10 mm Domino tenon stock for the price of this 3/8" cutter.
Re: Domino Hack Details
William Duffield
NB - If you are going to use the "hack" of cutting the through mortises in both legs with a single plunge, and are using the smaller DF500 Domino machine, it's maximum plunge depth is 28 mm (about 1-3/32"), so you can't do it in 3/4" thick stock. The larger DF700XL is not that limited, as it's maximum plunge depth is 70 mm (about 2-3/4"). It makes it easy to simultaneously cut a pair of perfectly aligned mortises in a pair of legs over an inch thick (or through 5 legs made of half inch stock).
You got that right!!!!
$195 for a cutter? I don't think so! And Its for a 700 model and I have a 500. Another $1400 for the DF 700. Nope. I had looked into getting a custom cutter but the price made it economically impossible.
In a Duhh! moment it dawned on my that I could run them through my planer and reduce them to 8 mm and they work perfectly. The width is exactly correct for the 8 mm mortise. So I made about 200 of each 50 and 40 mm length and am enjoying them.
Would anyone like to buy a supply of sticks that are easy converted to 8 mm Dominoes?
