table leaves don't line up with table
Susan
I ordered a table online that has 2 leaves. The leaves will not close tightly into the table because the dowels and holes are not lined up correctly. I have called the company and they said we can remove the dowels and they will give us 25% off of the table. My concern is that the leaves will then shift as the table is 106" long with both leaves installed. The table does have latches underneath to hold the leaves together. Any advice is welcome. Thanks.
Re: table leaves don't line up with table
find a local wood worker
It is a trivial job for an experienced woodworker to install dowels correctly. There may be a woodworking shop near by. Or if there is a woodworking store the store personnel will know someone that can do it.
Where do you live?....someone here on WoodCentral may be nearby.
Don Stephan
Give credit where credit is due. What is the names of the on-line seller and the manufacturer?
Really twists my knickers that factories can get away with this for only 25% off and so many artisan woodworkers can't make a living wage.
How bad off is the alignment?
Keith Newton
The " easy fix" as Bill states may or may not so easy, depending on how close or far off they are now.
It is much easier to fix, if the pins are off more than the width off the pin diameter, because your drilling new holes into new wood. It becomes a lot harder drilling new holes overlapping an existing hole.
Is the misalignment up and down, or side to side, or both, and by how much? We can give you more meaningful advice for how to adjust if you can give more precise answers.
25% of how much? I have a friend who bought a dining table and 6 chairs about 7 years ago that needed some assembly that I helps with. Three of the chairs had some parts assembled backwards. The friend called, and another box came with new chairs the next day, with no questions ask, which was great, because it was all solid wood, and a pretty nice design. However, the thing that astounded me, is that I've been building cabinets and furniture for about 40 years, and I couldn't even buy the raw lumber for as little as she paid for this whole set, made, assembled, finished, boxed, then shipped from the other side of the World. I dont know how they can do all that for so little money. But 25% of a small number may not go very far to fix this on this side of the planet.
I stand by trivial
I stand by my "trivial to fix". Where ever the holes are located I would leave the pins in place, plug the existing holes and drill new ones to line up. Or if the pins came out easily I would do the opposite because it is easier to locate a pin from the mating hole. Whatever, trivial. If Susan is nearby I'll do it for free just because she asked politely.
What probably happened
The holes got made and then either the end to end orientation of the leaf got changed or the opposite side of the leaf became the top surface. I have fixed this problem before as well as replaced damaged pins and/or holes.
Gary Smyth
When other methods fail or are too expensive. There are latches that can put together the leaves and "lock" them into place. Look under "under table latches images" and get a full range of options.
ebd
+1 for trivial
ebd
Instead of bothering to try to realign a new pin with an old hole, or to pull the pin and install a new one aligned with the old hole, or to plug the hole and redrill - just pull/cut off the pins and redowel in different places. With a decent jig it's more than trivial. For two leafs maybe a leisurely half hour total and could be done in place.
BTW I really like the idea of latches posted farther down though they might be harder to engage than just popping the leaf in and shoving the table closed. It would take a bit more time than re-dowling as well, but not a whole lot.
