OT Moving laundry from basement to main floor
Alan Young
Alan Young
Our laundry is currently in our basement-A house from @1895- We want to move it to the man floor off the back door. I can run black pipe for the gas dryer and any necessary electrical for the washer and dryer. I can also run the H & cold supply lines to the washer- My question has to do with the drain for the washer. The washer will not empty into a tub but will need to run directly to the main drain pipe-The path is "clear" enough-but do I need to vent this drain? Or at least put a p trap in the path?
Re: OT Moving laundry from basement to main floor
John Veerkamp
It needs a trap to prevent sewer gasses (dangerous) from getting in the house.
Run a 2" line with a trap and a fairly tall standpipe and you do not need a vent. The line is self venting because the hose from the washer is not sealed to the drain.
Also, remember that for a gas dryer the dryer vent is considered similar to a flue and must be in metal hard pipe not flex pipe, not even the metalized type.
Dave Bair
You also need an air gap where the drain hose enters the drain line to prevent siphoning.
Lee Schierer in McKean, PA
Yes it needs both.
You also need a local gas shutoff and a metal exhaust piping.
Lee
PS....
You should also install a pan under the washer with a drain. Not a big deal in the basement with a concrete floor but it may payoff big time on a wood floor.
PSS.... If the drain hose is a loose fit, that is an air gap and the reason I said to use a taller standpipe was that modern machines pump out so fast you need a little storage capacity in the pipe until the water starts moving.
Re: OT Moving laundry from basement to main floor *LINK*
John in NM
2" line, with a trap. If you want to play it safe, vent it. If the hose from the machine is not an airtight fit it should self vent (keeps the trap from being siphoned empty when there is a big slug of water running down the drain). In most cases I vent it if I can without moving heaven and earth to do it.
As Lee said, gas shut off at the appliance and good metal pipe for the dryer vent - keep flex stuff to an absolute minimum and avoid all together if you can. Last one I installed (electric, so less of a big deal) I got a telescoping galvanized L-box thing (in link) instead of the flex line from the dryer to the wall.
https://www.homedepot.com/p/Smart-Choice-0-18-in-Dryer-Periscope-Vent-Kit-5304484130/206740122
A.J. Hamler
Another thing you'll need to do
A.J. Hamler
And don't forget that once you get the washer and dryer out of the basement, you'll need to collect some sawdust and carry it upstairs to manually add it to the wash.
A.J.
Alan Young
Thanks! taking many Notes!
Re: Shark bite
Jerry Gibbs
These fittings are a miracle. I could have used pex without buying crimping tools to connect to washer faucets and basement supply. Would have made life easier. The cost for a small job is small compared to the benefits.
Kneale Brownson
Kneale Brownson
I really like the supply and drain combination installations for washer supply and drain like this. The capped opening is the top of the standpipe Barry suggested.
Why Bother?
Gee, that sounds like a lot of work. Don't you have a laundromat in your town? Or at least a river and a good wash board? T.
Kneale Brownson
Re: Why Bother?
Kneale Brownson
It snows in Ypsilanti and your clothes wouldn't get really clean in the Huron River.
