Testing a glue joint.....
Unintentional, but a test anyway. I have been posting about the grandfather clock I built fifty years ago. A glue joint in the front of the base failed years ago. I decided to take the Front off the base and replace it with one with a free floating panel. The joint on one side had failed, but the one on the other side was still sound. I was sure that joint would pop loose with a little pressure. NOT!
The wood broke. On the side and I had to glue it back.
The point is that the fifty year old edge to edge glue joint was still stronger than the wood. The glue was Elmer's white glue. So make those joints up nicely and clamp them well and they will last longer than you do.
