6" Rockwell bench grinder/buffer
Rancy Ceccotti
I have a vintage Rockwell serial #8E48C17T8H. I am missing the nut for the right side. I have the left which is a left-handed thread. The shaft measures 16MM. I have tried both fine and coarse threaded nuts and neither are compatible. Is the thread specific to Rockwell? Any help!!!!
Re: 6" Rockwell bench grinder/buffer
Gary Smyth
if you haven't already done this find a thread gauge. At least find out the threading. Then use thar ro find what you need. Lots of gauges to choose from-- the one shown is a Starrett-- others work just as well.
Rancy Ceccotti
I have already done that. It is 20 TPI but where do I find a nut or does it have to be made. Nowhere in my area has 16MM with 20 tpi
JohnV
Granger's web site indicates they have it.
Don Stephan
I didn't think Rockwell equipment was made with metric fasteners.
I think you will find the nut to be 5/8"
Keith Newton
I think Don is right. I don't think you could expect the shaft diameter to be metric, then find thread pitch in inches. A fine 5/8" is 18 tpi. If it is 16mm, then it would probably be .8mm to equal ~20 over 1".
Mike Jurnigan in Zuni VA
The model number would be more helpful than the serial number.
I have a similar grinder from about 1972. I can take the right nut off and look at it if you would like. Maybe Fastenal could match it.
Chuck
If your thread is 20 tpi, then you most likely have a 1/2"-20 nut or threaded shaft
Rancy Ceccotti
Thanks for all your replies. I contacted Rockwell and I was incorrect. It is not a Grinder/Buffer though it does have 2 spindles. It is only considered a buffer. The model number is 438-02-314-0204. A Delta rep says it is also listed as a Lot #139. I have tried both 5/8" SAE both fine and coarse and 16MM metric both fine and coarse. Nothing is compatible. I do have a number for Renovo Parts but have not been able to reach them. Thanks for your help
Re: 6" Rockwell bench buffer
Rancy Ceccotti
FYI The nut I needed and found is a 5/8 X 13 Acme thread (not standard). After much searching I located a man named Steve at Delta Tech Service (800-223-7278). He is a walking encyclopedia on both Rockwell and Delta. If he cannot answer your question from memory he has an entire library at his disposal.
