Should a VFD make a motor run unevenly?
Henry Higginbotham
A while back I bought a very rough Clausing 20" drill press as a restoration project. I also picked up a 3-phase, 2hp Baldor inverter duty motor, thinking I would run it with a VFD, and retain the Reeves drive on the drill press for even more speed flexibility.
Then a few weeks ago I got a Teco VFD via eBay. Single-phase input and rated for 2 horsepower. It works and was easy enough to figure out setting it up, but the motors I've powered with it at less than 60Hz run with an uneven "bumping" that's especially obvious when I touch the motor. (The current draw goes way up at lower frequency, too, and shuts down the VFD, but I sort of understand why that's happening).
I don't have much prior experience with VFDs. Is the unevenness to be expected, or did I get a lemon?
